seismograph Posted August 17, 2002 Share Posted August 17, 2002 ok, this is a cheezy Screenshot: after some modifications of the original mesh i imported it into lightscape, disabled that selfillumination of the walls, start processing, that was finished within 2 minutes. then i changed the orientation and process again to match the image... btw, the camera is shifted! Next thing will be a RT chatroom of it Link to comment Share on other sites More sharing options...
Guest dn Posted August 17, 2002 Share Posted August 17, 2002 The light set up is pretty cool... But the water and the grass need work.. A grate start. Can’t wait to see the next version Link to comment Share on other sites More sharing options...
seismograph Posted August 17, 2002 Author Share Posted August 17, 2002 i think it's finished now.... Go here to dL the RT- Chat (800kb) !!! IMPORTANT -- THIS WORKS ONLY WITH BLAXXUN !!! just tell me waht you think. [ August 18, 2002, 01:15 AM: Message edited by: seismograph ] Link to comment Share on other sites More sharing options...
NenadK Posted August 18, 2002 Share Posted August 18, 2002 i agree --- very nice soft lighting, altough needs more mesh refinement and maybe looks a bit flat. you should only correct the mesh to avoid shadow leaks. if you're using lightscape as your final rendere (ie. not importing the solution file back to MAX or VIZ) you might encounter some problems in future with the soft shadow from sun - to avoid jagged look you should either make mesh subdivisions smaller or experiment with raytraced soft shadows. in a word - great start, seismo Link to comment Share on other sites More sharing options...
seismograph Posted August 24, 2002 Author Share Posted August 24, 2002 some other technique with lightscape: I now can say: no mesh was harmed by processing this image in lightscape one minute of hdrshop and photoshop. Link to comment Share on other sites More sharing options...
