alikashan Posted November 28, 2006 Share Posted November 28, 2006 i cant figure it out without window glass room is rendering ok but when i put a window glass my sky goes away?? i have images attached. i m using physical camera and sun/sky feature. glass window has the same material as glass blobs ????? any ideas:rolleyes: Link to comment Share on other sites More sharing options...
pg1 Posted November 28, 2006 Share Posted November 28, 2006 is the glass in the window part of a multi-sub object material? Link to comment Share on other sites More sharing options...
alikashan Posted November 28, 2006 Author Share Posted November 28, 2006 nopes its not ??? Link to comment Share on other sites More sharing options...
pg1 Posted November 28, 2006 Share Posted November 28, 2006 vray has a bug where glass as a multisub object doesn't render correctly check the affect alpha box Select the glass layer and turn off visible to GI in vray properties Also I read this in another post I remeber that I read somewere that to let the light pass correclty trough glass wall you had to check (in the GI -Indirect illumination- general settings) the GI caustics to reflect and refract, doesn't matter if you don't check caustics on in the caustics tab. Link to comment Share on other sites More sharing options...
alikashan Posted November 29, 2006 Author Share Posted November 29, 2006 the problem is with vray physical camera i dont what exactly but it rendered correctly with the normal max camera. in this scene i just reduced the sun multiplier.and i m using standard camera. what i m doing wrong with the phyical camera any thoughts. Link to comment Share on other sites More sharing options...
alikashan Posted November 29, 2006 Author Share Posted November 29, 2006 ok i found out i was using a hdr in my reflection slot that was creating the problem now its working just fine. Link to comment Share on other sites More sharing options...
