Measuring in Max
hereagain
I'm trying to find a quick and easy way of making measurements in Max for aligning objects. I really like the ease of the Tape Measure tool in Sketchup for laying out construction lines which are easily identified and not confused for actual line work in the drawing. Does anyone work like this in Max or is there a different approach to placing objects at particular locations? Thanks.
  • 2 weeks later...
I would disagree. I used to think the snaps were rubbish, but once you start using them in conjunction with the constraints and (the tick-box it took me 6 years to discover) 'start new object' they become very logical.
And the quickest measure tool is in 'measure distance' in the tools(?) dropdown.
Not trying to argue with you - cuz if you are happy, that is great, but if you come from any type of CAD package that has countless ways to measure and snap to object, MAX's methods do indeed suck.
I think max can improve this feature allot, maybe put in something that you can select two or more points and it then gives a visible reading of the measurements that also have a render option so one can actually use it in a render. Also giving it a style option dialog box so one can create one's own style, something such as the text object creator.
