Koper Posted December 1, 2006 Share Posted December 1, 2006 Something quick that I have been pondering for some time (a noob question:p ) on a drawing, what does the triangles on windows and doors actually mean? does it indicate the hinges of the doors and if a windows can open? Link to comment Share on other sites More sharing options...
BobM Posted December 1, 2006 Share Posted December 1, 2006 You are right that is what it represent Link to comment Share on other sites More sharing options...
James Posted December 1, 2006 Share Posted December 1, 2006 In my experience, yes, it indicates which way a door or window is 'hung', ie. which way it opens. I have had arguments with colleagues regarding the correct usage of the notation. Personally, the point of the triangle indicates the edge which is hinged, while the two ends of the line indicate the leading edge of the door/window. Other people I know do it the other way round. Link to comment Share on other sites More sharing options...
Macer Posted December 1, 2006 Share Posted December 1, 2006 James has got it right. At least thats the way it is used in the prctice where I work! Example: with a set of standard double doors the symbol should form the shape of a large diamond. Link to comment Share on other sites More sharing options...
Koper Posted December 1, 2006 Author Share Posted December 1, 2006 thanks for the replies hehehe, at the moment I am working with X's and not diamond's with double doors. I also have this 'triangle' shape on a wood frame, this probably means that the window slides in the direction of the triangle. cool, thanx Link to comment Share on other sites More sharing options...
STRAT Posted December 1, 2006 Share Posted December 1, 2006 nube yup, the triangle means it hinges where the triangle's apex is. an X means it's double hinged. all as James said Link to comment Share on other sites More sharing options...
