bradpski Posted December 1, 2006 Share Posted December 1, 2006 hey all, i just started using 1.5 and im trying the vray sun and sky for the first time but everything is comming out very very bright and over exposed, i was wondering is there a tutorial or some basic standard setup rules i could use, thanks, brad. Link to comment Share on other sites More sharing options...
BrianKitts Posted December 1, 2006 Share Posted December 1, 2006 http://www.vrayelite.com/camsky.php Link to comment Share on other sites More sharing options...
AJLynn Posted December 1, 2006 Share Posted December 1, 2006 It's been discussed here an on Chaosgroup's forum. Basically, the light level from the sun is much higher than a normal Max light would be, which you can compensate for by dropping the sun and sky values or using the VrayPhysicalCamera with ISO, shutter and aperture set as you would use with an SLR in daylight Link to comment Share on other sites More sharing options...
bradpski Posted December 1, 2006 Author Share Posted December 1, 2006 thanks, actually straight after i posted this i found what i was looing for, thanks anyway!! Link to comment Share on other sites More sharing options...
