aflack Posted December 4, 2006 Share Posted December 4, 2006 Hi, I've placed a sky jpg in the viewport background slot in Max 9 as well as the effects/environment slot. I'm then using a Vray material for the water, the problem is I don't get a reflection of the background in the water, any idea what i need to do to get it? Thanks. Link to comment Share on other sites More sharing options...
ipxstudios Posted December 4, 2006 Share Posted December 4, 2006 you might have to create a billboard and map the sky onto that - it will reflect if you do that. Link to comment Share on other sites More sharing options...
BrianKitts Posted December 4, 2006 Share Posted December 4, 2006 shouldn't be any reason to have to billboard your background. Does the background show up in the rest of the image...just not in the reflection of the water. sounds more like a problem with your water material settings, perhaps you could post them...... Link to comment Share on other sites More sharing options...
Nic H Posted December 5, 2006 Share Posted December 5, 2006 goit your sky map set to environ and screen mapping? Link to comment Share on other sites More sharing options...
aflack Posted December 5, 2006 Author Share Posted December 5, 2006 Yep the environment map is pulled into a material slot and is set to environment and screen. This use to work before I installed 1.5 I'm sure. I've attached my water setting but they are just pretty straight forward. I wasn't sure whether to post this in the vray or Max thread maybe someone would have an idea over there. Link to comment Share on other sites More sharing options...
jkletzien Posted December 8, 2006 Share Posted December 8, 2006 I'm guessing it is reflecting black? like the bottom half of your background.... In Photoshop Just take your background image from the horizon line up, and paste it upside down over the lower part of your background image. Reflections that find screen mapped backgrounds go to the straight background, and don't reflect what is above them. It is a Max characteristic not a VRay one. Link to comment Share on other sites More sharing options...
Tim Saunders Posted December 8, 2006 Share Posted December 8, 2006 I'll echo what Jon just said. I had a similar problem until I used a spherical environment. If that's not an option, screen environment is nice because you know exactly what will reflect. Also, I find with wavy water, it looks way better with fresnel reflections. Link to comment Share on other sites More sharing options...
