bradpski Posted December 4, 2006 Share Posted December 4, 2006 hey, i just started using the vray sun and sky with physical cam, and the render looks great but i need to use the color correct in the frame buffer to bring the darkness up in my scene, my question is... after i adjust it to where it looks good, then next time i render my scene the information stays the same in the color correct, is there a way to reset this before each render? Link to comment Share on other sites More sharing options...
Christopher Nichols Posted December 5, 2006 Share Posted December 5, 2006 hey, i just started using the vray sun and sky with physical cam, and the render looks great but i need to use the color correct in the frame buffer to bring the darkness up in my scene, my question is... after i adjust it to where it looks good, then next time i render my scene the information stays the same in the color correct, is there a way to reset this before each render? The reason you need to bring the darkness up is that you are not using the proper LWF. If you don't care about working in full linear color, simply add a 2.2 gamma to the light mapping. Now your color will be correct. Link to comment Share on other sites More sharing options...
