Microstation + Maxwell WIP image
Phil Shields
Hi guys
WIP image of proposed shop, rendered over night.
I guess for those like me, who don't need to do rendering very often, then Maxwell is an acceptable option. For me Microstation, 3DS Max & Vray, is a lot to pay for, and keep updating every year.....especially as my boss prefers watercolors!
I guess it depends on your budget and the number of images you intend to produce.
Also the work flow is a lot simpler...and Maxwell is easy to use!
All C+C welcome...I need it
Well just my 2 cents worth.
Cheers
Phil
Thanks guys
I could tweak the carpet textures in PS to remove the patterning effect, but I'm not sure this is enough to make it convincing?
The bronze facade is too reflective, I've attached another test with lower reflection, but it looks a little flat to me....something in-between perhaps?
Not sure about the caustics on the plaster walls, but I guess these could be removed in PS
Ummm yes...noise is a problem, even heavily filtered it persists, perticulaly in the showcase...
Cheers:D
Phil
Hi
Thanks for your comments rpompeu
I have tweaked the carpet and agree, it does still need some more work.
I will try it with a bump map, like you suggest.
well the lighting...this is Maxwell's magic I guess :D
The noise is filtered with some areas touched up in photoshop, obviously
not ideal, but I hope the result is still quite passable
Cheers
Phil
