Need Help!!! in vray
tejalvirkar
What are your light sources? Those splotches are often the result of small light sources, ie., lights that have a relatively smaller impact on your scene. Trying removing all but the largest light source, the sun, and add the other lights one by one while rendering in between until you see which is causing this. For example, it might be those tiny ceiling lights causing all the problems. Not saying you have to do without them but knowing the problem is half the battle. If they are the problem, you might try a different type of light or illumination source.
  • 1 month later...
agree with brian smith,..... really these images are looking weired to me. there is no concentration on lighting , texturing.. and the effect .... i :confused: what type of lighting is this.... what is the effect you want to show...
