Sketchrender Posted December 5, 2006 Share Posted December 5, 2006 I have modeled a house in Max 8 with Power Booleans. I now want to bring it into Viz 2007, which dose not have Power Booleans. All the walls disappear....why.#? How Do i get around this problem.? Thank you in advance. phil Link to comment Share on other sites More sharing options...
oluv Posted December 5, 2006 Share Posted December 5, 2006 if you select the power boolean objects in max what does it say what type of object this is? maybe you can convert everything to mesh or poly, this way it should be readable in viz. Link to comment Share on other sites More sharing options...
Brian Cassil Posted December 5, 2006 Share Posted December 5, 2006 Yep, you need to convert it to editable poly or mesh and then you'll be sailin. Link to comment Share on other sites More sharing options...
