Chad Warner Posted December 5, 2006 Share Posted December 5, 2006 I have a DVD that I'd like to find out what framerate, interlacing, compression, etc. is being used to create the clips on the DVD. Does anyone know of a program or a method to obtain this information? Thanks, Chad Link to comment Share on other sites More sharing options...
Tim Nelson Posted December 5, 2006 Share Posted December 5, 2006 Well you could find the .vob files on the dvd and rename them to .mpg. Then you can bring those into Premiere and it may give you some info, but more than likely it will be at 29.97 fps if it is in ntsc format. Also, all dvd's are encoded in mpeg-2 format. Link to comment Share on other sites More sharing options...
jucaro Posted December 5, 2006 Share Posted December 5, 2006 at http://www.free-codecs.com there is a freeware that can derive information about a video file. standard ntsc DVDs use a frame rate of about 29.97 at 720x480 OR you can use a MPEG2 Decoder and Frame Server, based on DVD2AVI and MPEG2Dec. these frame servers can also extract information about vob files without the need to decrypt the dvd. Link to comment Share on other sites More sharing options...
Chad Warner Posted December 5, 2006 Author Share Posted December 5, 2006 Downloading one now, I'll let you know how it works. Thanks! Link to comment Share on other sites More sharing options...
martin walker Posted December 5, 2006 Share Posted December 5, 2006 If you have Sony Vegas, you can open up the vob file and delve straight in Link to comment Share on other sites More sharing options...
Chad Warner Posted December 5, 2006 Author Share Posted December 5, 2006 I downloaded "media info" from the link that jucaro provided, and it gives a lot of info about the VOB file. Including framerate, bitrate info, interlacing info, and a bunch of other things. Link to comment Share on other sites More sharing options...
helmutcad Posted December 29, 2006 Share Posted December 29, 2006 Well, TmpgEnc is very useful for this. Recomended Link to comment Share on other sites More sharing options...
