aweber Posted December 7, 2006 Share Posted December 7, 2006 I´m trying to make a pano 360 of an interior, with vray 1.5 RC3 and max 9. I check the camara type to spherical , and override FOV to 360 degrees. I think thats the way. But when i render i get the same image of the Physical camera i have in the render-viewport-setting. If i set this last setting to "perspective" i get the correct panorama, but it is burned, because i used the camera settings to iluminate the scene. Am i doing something wrong? Link to comment Share on other sites More sharing options...
KSciortino Posted June 11, 2007 Share Posted June 11, 2007 I know this is a really old post but did you ever find the answer to your question? I'm sorta having the same problem and was wondering what you did to fix it. Thanks. Link to comment Share on other sites More sharing options...
Mechadus Posted June 11, 2007 Share Posted June 11, 2007 I had to do a panorama for a client before - I rendered regular frames from VRAY (I rotated the camera 20 degrees for each render) and then used a free app I found on the net to stitch the images back together. I cant for the life of me remember what the name of the software was, but there are tons of packages available out there. I then just saved out a .JPG of the panorama, and gave it to the web department (I have no flash skills to speak of ) -Nick Kropat Sr 3D Artist http://www.3Dwebmedia.com Link to comment Share on other sites More sharing options...
KSciortino Posted June 11, 2007 Share Posted June 11, 2007 Thanks for the info. I believe I'm going to try the same thing. I've been trying to use the VRay panoramic exportor with no success but I believe I can do it the way you are suggesting. I really don't have any Flash skills to speak of either and that's where this will be going when I'm through with it. Thank ya much!! Link to comment Share on other sites More sharing options...
olli96 Posted June 11, 2007 Share Posted June 11, 2007 check out these threads: http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=19344 http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=19537 i used cubicVR for this one: http://olli96.net/VR/StoneCold_VR.mov you can download it here: http://plugins.angstraum.at/cubicvr/index.htm Olli Link to comment Share on other sites More sharing options...
