frame buffer question
The_architect06
hello everyone..
my problem is that in the old versions of vray i used to check where is my reflections,specular,lighting & gi is hapenning in each render by using the drop down in upper left of the rendered image ...Now in the 1.5 + i can't check none of them ( i only have RGB & Alpha) & the is no G-buffer rollout in the renderer..is there a way to bring this option back,am using vray 1.5 RC2 ?
instead of adding the channels to the G-buffer where it used to be, it is now a separate tab in your render dialog. to the right of "common" and "renderer" you should have a tab called "render elements" thats where you can select your extra channels and paths for saving them
except I'm thinking that they didn't get that added till RC3. It might not be in RC2, you may need to get yourself updated to the latest release.
