The_architect06 Posted December 9, 2006 Share Posted December 9, 2006 hello everyone.. am having my vray crashing during rendering (during prepass 1)..this never happened with me before ,only with this scene am working on , & i can't figure out why.. i have lots of materials with use interpolation checked on & also am using lots of displacement maps..could this be a reason for vray or max crashing ? ! Link to comment Share on other sites More sharing options...
The_architect06 Posted December 9, 2006 Author Share Posted December 9, 2006 ok..now...i rendered the scene with a 320*240 & it rendered fine,it seems it crashes with higher resolution like 1000*750 & up, am using 3.4 dual core with 2G ram anyone have encountered a similar issue ? Link to comment Share on other sites More sharing options...
ipxstudios Posted December 9, 2006 Share Posted December 9, 2006 it probably is the displacement maps - you could try rendering them out separately then combining in photoshop. Link to comment Share on other sites More sharing options...
lambros Posted December 9, 2006 Share Posted December 9, 2006 I assume that you are using vray displacement, right? Link to comment Share on other sites More sharing options...
The_architect06 Posted December 10, 2006 Author Share Posted December 10, 2006 I assume that you are using vray displacement, right? yes but am using it through material editor not as a modifier Link to comment Share on other sites More sharing options...
njoco2 Posted December 10, 2006 Share Posted December 10, 2006 Same thing happens to me when I use V-ray displacement maps in large scenes. I have Athlon 3800+ with 2GB ram, and when the ram counter hits ~1.5GB while rendering max crashes. The way I get around this is rendering the scene without displacement maps, then render just displacement maps....the rest is Photoshop work. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted December 10, 2006 Share Posted December 10, 2006 Same thing happens to me when I use V-ray displacement maps in large scenes. I have Athlon 3800+ with 2GB ram, and when the ram counter hits ~1.5GB while rendering max crashes. The way I get around this is rendering the scene without displacement maps, then render just displacement maps....the rest is Photoshop work. Mostly likely a ram issue which could be solved wiht ehs displacement tweaks. For now, try the memory to dynamic in the system tab, and see if that solves it. Will be slower, but should not crash. Link to comment Share on other sites More sharing options...
The_architect06 Posted December 10, 2006 Author Share Posted December 10, 2006 Mostly likely a ram issue which could be solved wiht ehs displacement tweaks. For now, try the memory to dynamic in the system tab, and see if that solves it. Will be slower, but should not crash. yeah..it looks like a ram issue,i now checked my task manager when max crashed & it was using 1.6 GB of my ram Link to comment Share on other sites More sharing options...
chow choppe Posted December 11, 2006 Share Posted December 11, 2006 my suggestion would be go for win x64 bit it has 4 gb support it solved all my crashing problems hope it helps Link to comment Share on other sites More sharing options...
