Pete_OZ Posted January 20, 2004 Share Posted January 20, 2004 My first post, WIP of an alley way. trying different effects. I have used Autocad 2k, 3ds max 5 and photoshop. Any suggestions for achieving realistic rain? Pete. http://www.cgarchitect.com/forum/filepush.asp?file=set3.jpg http://www.cgarchitect.com/forum/filepush.asp?file=set4.jpg Link to comment Share on other sites More sharing options...
Wojciech Klepacki Posted January 21, 2004 Share Posted January 21, 2004 Hi, Nice start If u want more realistic rain effect, u could use particle system with motionblur on it. U should play with lights, they need more attention. U could also use some "dirty" maps to achieve better mood. rgds, Wojciech Klepacki Link to comment Share on other sites More sharing options...
Pete_OZ Posted January 22, 2004 Author Share Posted January 22, 2004 thanks for the tips, I added dirt to the conc on the left. I put some motion blur on the rain but I think i will have to work on that a bit more. Pete. http://www.cgarchitect.com/forum/filepush.asp?file=set5.jpg Link to comment Share on other sites More sharing options...
IC Posted January 23, 2004 Share Posted January 23, 2004 That's looking much better. I like the red reflection but the sign doesn't look big/bright enough to cause that effect. Cheers, Iain Link to comment Share on other sites More sharing options...
Ernest Burden III Posted January 23, 2004 Share Posted January 23, 2004 I would like to see more variation in the ground surface--raindrops hit the ground--and the papers collected along the edges. I know that is hard to do, but you started it, do it right. The brick scale looks too small to me, maybe it isn't but that's how I see it, also the texture seems blurred compared to the sharpness of the rest of the textures. Why do the window frames project so much? That is very distracting. The garage has lower contrast than the rest, which isn't necessarily bad, but it is a structure that shows a lot of depth and detail as you see into it, so I would expect matching contrast to the picture as a whole. Better to have lower contrast only at the back of the garage than the whole thing. Is it a flat map? Finally, try moving the car to the other side of the view, showing just the back end rather than the front. Believe it or not, I think that will make a big difference in the mood of the picture. Seeing the front directs your mind towards the right along the street as you expect the car to go, thus spoiling the linear nature of an alley. By using a garage on the other side you invite the viewer to go down the alley, across the street and deep into the garage structure. But the car front spoils that. Show the back end leaving and you will not be pulled off track. It sounds like I am taking the picture into the psyciatrist's office and asking about its childhood. Link to comment Share on other sites More sharing options...
Munz Posted January 23, 2004 Share Posted January 23, 2004 There is an awesome animated short that I am sure many of you have heard of, Rustboy. http://www.rustboy.com/rustweb.htm If you go to this site and go to the "making of". The third part is how he did his animated rain. Very nice stuff. munz Link to comment Share on other sites More sharing options...
Ernest Burden III Posted January 23, 2004 Share Posted January 23, 2004 Originally posted by Munz: There is an awesome animated short that I am sure many of you have heard of, Rustboy.Getting off the thread, but for Rustboy gear: cafeshops/rustboy Link to comment Share on other sites More sharing options...
Munz Posted January 23, 2004 Share Posted January 23, 2004 The original post asked if anyone had suggestions on how to make realistis rain. I was directing him to the MAKING OF section on how the RAIN was done in that movie. munz Link to comment Share on other sites More sharing options...
Pete_OZ Posted January 26, 2004 Author Share Posted January 26, 2004 thanks again guys!, I am still working on it, this is the progress so far.. Ernest, the garage is a 3d object, I am not happy with it yet, I was going to add a bit more detail to the structure itself. I think it is getting there but I will keep on it for a while yet. cheers. http://www.cgarchitect.com/forum/filepush.asp?file=set7.jpg Link to comment Share on other sites More sharing options...
Pete_OZ Posted February 2, 2004 Author Share Posted February 2, 2004 this is the final picture. thanks again for all of your input. http://www.cgarchitect.com/forum/filepush.asp?file=final_1.jpg Link to comment Share on other sites More sharing options...
