shikodesign2000 Posted December 11, 2006 Share Posted December 11, 2006 Hi, I've made a color test for my present project, and when I put blue fabric on the floor, the white walls turn blue, I think this's for "color bleeding" effect. My question is: how can I control " color bleeding" in vray? and is there any other reason that makes the walls turn blue? Thanks so much.. Sherif Massoud http://www.3dshore.com Link to comment Share on other sites More sharing options...
Nic H Posted December 11, 2006 Share Posted December 11, 2006 Right Click - Vray properties - put Generate GI on a lower value like 0.7 or lower. This shpuld reduce bleed. Link to comment Share on other sites More sharing options...
CookiE Posted December 11, 2006 Share Posted December 11, 2006 nicnic said: Right Click - Vray properties - put Generate GI on a lower value like 0.7 or lower. This shpuld reduce bleed. I have had the same problem but doing what you say there seems to just make what ever you turn the GI down on darker? Link to comment Share on other sites More sharing options...
Craig Ramsay Posted December 11, 2006 Share Posted December 11, 2006 Try lowering the saturation value located in the Indirect Illumination rollout Link to comment Share on other sites More sharing options...
Christopher Nichols Posted December 12, 2006 Share Posted December 12, 2006 If you work in LWF (the proper way to light), you will get the correct amount of color bleeding. If you don't your darks will be very saturated, hence it will look like there is too much color bleeding. Link to comment Share on other sites More sharing options...
CookiE Posted December 12, 2006 Share Posted December 12, 2006 Well i dont even know what LWF is Link to comment Share on other sites More sharing options...
Craig Ramsay Posted December 12, 2006 Share Posted December 12, 2006 CookiE said: Well i dont even know what LWF is Linear work flow Link to comment Share on other sites More sharing options...
Craig Ramsay Posted December 12, 2006 Share Posted December 12, 2006 Oh and if you are working in V-ray 1.5 you have the option to use a V-ray override material on the floor too so plenty of solutions to your problem. Link to comment Share on other sites More sharing options...
shikodesign2000 Posted December 12, 2006 Author Share Posted December 12, 2006 Hi guys, Thanks to you all, I made it, finally.. Best regards, Sherif Link to comment Share on other sites More sharing options...
