ktm07 Posted December 12, 2006 Share Posted December 12, 2006 Hey all! I have a project that requires a wall to be built of a backlit translucent material. I achieved this by adding the texture map to a vray light material and it works very well. Problem is that them material is also reflective and I don't know how to achieve this when doing it this way! Can anyone help??? Thanks! Tom Link to comment Share on other sites More sharing options...
Craig Ramsay Posted December 12, 2006 Share Posted December 12, 2006 What version of Vray are you using? Link to comment Share on other sites More sharing options...
manta Posted December 12, 2006 Share Posted December 12, 2006 put glass in front of it... Link to comment Share on other sites More sharing options...
Craig Ramsay Posted December 12, 2006 Share Posted December 12, 2006 If you are using V-ray 1.5 you can use a blend material to do what you are after. Keep your Vray light material as the base material and put a reflective material in the 1st coat slot. You can then play around with the blend amount until it looks correct. Link to comment Share on other sites More sharing options...
Tim Saunders Posted December 12, 2006 Share Posted December 12, 2006 Sounds like a candidate for the new 2-sided material if you ask me. I love that material! Link to comment Share on other sites More sharing options...
ktm07 Posted December 13, 2006 Author Share Posted December 13, 2006 Sorry, I am using Max 8 and vray 1.5 RC2. I have tried both the 2-sided material and the blend and neither is giving an acceptable result. The attached image shows what I am working on. The sloped wall is series of 4'x4'x1" onyx panels that are to appear backlit. I have a multi-sub material that assigns one of 27 different maps to the wall. I assume that I am having problems with the 2-sided material because the panels have thickness. The blend sends my rendering times thru the roof (10x as long). Any thoughts are appreciated! Tom Link to comment Share on other sites More sharing options...
-MerlyN- Posted May 1, 2010 Share Posted May 1, 2010 If the blend material doesnt work out put a glass plane infront of your wall, set refraction to 255 and adjust the reflection as needed. Link to comment Share on other sites More sharing options...
