nisus Posted December 13, 2006 Share Posted December 13, 2006 Hi All, I'm using the new Arch+Design material for glass in max9, bUt when I render, the transparancy does not transfer to the alpha channel. I really needs this alpha channel, how can I achieve this in one pass? rgds, nisus Link to comment Share on other sites More sharing options...
@win Posted December 13, 2006 Share Posted December 13, 2006 You must look in the special pupose map and use cutout for the alfa channel. Greets, @win Link to comment Share on other sites More sharing options...
nisus Posted December 13, 2006 Author Share Posted December 13, 2006 for regular glass too? sounds strange but probable... anyway, i wonder why it is not included in the preset than... rgds niSus Link to comment Share on other sites More sharing options...
@win Posted December 13, 2006 Share Posted December 13, 2006 Do jou use solid glass or thinwall glas? Link to comment Share on other sites More sharing options...
nisus Posted December 13, 2006 Author Share Posted December 13, 2006 Thinwall... Does that make any difference? nisus Link to comment Share on other sites More sharing options...
@win Posted December 13, 2006 Share Posted December 13, 2006 Do you use raytrace shadow or map shadow? If you use map shadow try to use raytrace shadow. Link to comment Share on other sites More sharing options...
nisus Posted December 13, 2006 Author Share Posted December 13, 2006 All RT... nisus Link to comment Share on other sites More sharing options...
@win Posted December 13, 2006 Share Posted December 13, 2006 i did the test and i see what your mening. Dit you use the same mapping in the transparancy collor? Dit helps by me. You can also use the shadow slot in the mental ray connection. Link to comment Share on other sites More sharing options...
nisus Posted December 13, 2006 Author Share Posted December 13, 2006 What do you mean by same mapping in the transparancy collor I mean, what mapping? Shadow shader could idd do it, but why do we need it... Arch+Design templates that don't work fine... damn! Like selling a car without wheels... (other from this, I'm VERY impressed by the MR implemantation in max9) rgds, nisus Link to comment Share on other sites More sharing options...
@win Posted December 13, 2006 Share Posted December 13, 2006 You have it about a alfa channel so i think you are using a bitmap. I am also verry happy with the new mr 3.5 an achi mat. It make it a lot easyer. If you are not using a bitmap can jou show me a preview rendering on what is going wrong? Link to comment Share on other sites More sharing options...
nisus Posted December 13, 2006 Author Share Posted December 13, 2006 Ok, it's pretty simple... I have a small scene with a balcony made out of glass and stainless steel (both arch+design presets). I have a daylight system and an MR Sky set up in my scene. When I render the image to a tif-file, the glass does not show up in the alpha of the final output image... and than the mystery began... rgds, nisUs Link to comment Share on other sites More sharing options...
Justin Hunt Posted December 14, 2006 Share Posted December 14, 2006 under the "advanced Transparancy Option" set the "transparency propagates Alpha-chanel" on JHV Link to comment Share on other sites More sharing options...
@win Posted December 14, 2006 Share Posted December 14, 2006 That Alpha Channal, I look the wrong way:confused: I hope the upper solution wil help, i am sure i go try it Thanks Link to comment Share on other sites More sharing options...
nisus Posted December 14, 2006 Author Share Posted December 14, 2006 Tnx Justin! That was sooo simple, damn! Still wondering why it's not checked by default... rgds, nisus Link to comment Share on other sites More sharing options...
