Trouble with DWGs
martin walker
You can speed thing up a lot if you try linking a modified .dwg file that only has a few layers in it. I usually make two copies of the (orginal dwg) file. In one file I delete everything, and in the second file I use the paste into original coordinates command to paste in one layer at a time. It takes a little setup but it is worth the increased speed in Max. It makes Max much easier to navigate.
