Hospital Entry
cjlopez4
My vray sun is set to .9
vray sky - default
shadow subdivisions: 30
diffuse sub (sun) 1200
irr - 50
int samples - 25
f16/125/100
saturation - 1
contrast - 1.3
contrast base - .5
I'm just not getting realistic lighting with these settings. Must be my materials. Does anything seem off from the settings shown?
Hmm intersting point, this combination of Vraysun + sky + p-cam is causing more trouble here and there. I had a nice struggle getting my background up to normal colours. Your's seems fine, just a little playing with settings will help. I used f4/250/200 to start with and than only upped the shutter speed.
For the composition I would be tempted to widen the picture and lower the hight so you a different proportioned image.
please post again with your new render and settings!
Cheers
Ronald
beside of the other fellows all ready say, that i agree with, i think you may are using the wrong color mapping, you should be using the linear multiplier or exponential with some adjusment on dark multiplier
Thanks for the comments, I am using Gamma 1/.454. I will try linear next go-round.
With linear, do I need to adjust gamma in the preferences anywhere in max?
Also, Do I save with an adjusted gamma of 2.2?
