kent Posted December 14, 2006 Share Posted December 14, 2006 Back to the drawing board am not getting the reflections i want how can i acheive them, i have tried putting a tree to reflect but that did not work and all the setting in vray for the glass seems to be o k help kent Link to comment Share on other sites More sharing options...
Trevor Tizard Posted December 14, 2006 Share Posted December 14, 2006 Can you post your settings....... Link to comment Share on other sites More sharing options...
kent Posted December 14, 2006 Author Share Posted December 14, 2006 The settings for the glass _ diffuse black reflect white same for refract, fresnel on, subdivs etc defaults is this any help? kent Link to comment Share on other sites More sharing options...
tdarcy Posted December 14, 2006 Share Posted December 14, 2006 Try increasing the reflection IOR to something like 3 Link to comment Share on other sites More sharing options...
pg1 Posted December 14, 2006 Share Posted December 14, 2006 do you have a hdri map in the enviroment slots ? instead of checking the fresnel box put a falloff on the reflection map slot of you glass material The go into the falloff map and set it to fresnel reflection. Now you can adjust the amount your glass will reflect using the black and white colour swatches in the falloff map. The top black swatch controls front on reflection and the white swatch controls the angled reflections. if you use the falloff map dont forget to uncheck fresnel reflections box or you will have done the effect twice. Link to comment Share on other sites More sharing options...
kent Posted December 14, 2006 Author Share Posted December 14, 2006 Thank you to all another problem solved pa ga good tips thanks heaps maybe when i get rich and famous i will be in a postion to help thanks kent Link to comment Share on other sites More sharing options...
