diegofer_9 Posted December 15, 2006 Share Posted December 15, 2006 Hi people, I was wondering if anyone had this problem before and can guide me on how to solve it. I used VIZ2007 for modeling this project and as you can see, it displays terrible when in FACETS or SMOOTH&HIGHLIGHTS mode. It also happens to other projects. Any idea what is causing this? Thanks a lot! Link to comment Share on other sites More sharing options...
AJLynn Posted December 15, 2006 Share Posted December 15, 2006 Are there overlapping polygons in there? Overlapping polygons will do that, as it tries to display both with unpredictable results. Also, where you see holes, there might be flipped faces. Is this a Sketchup model? One of my old students showed me a model from Sketchup with problems like this a couple weeks agoand the solution was to look at it in Sketchup's monochromatic display mode and flip any blue faces, and export a 3DS file using 2-sided faces as materials. Link to comment Share on other sites More sharing options...
diegofer_9 Posted December 15, 2006 Author Share Posted December 15, 2006 Hi Andrew, thanks for your reply. Unfortunately, there are not co-planar faces there, it is just a polygonal gox, and the faces are "facing" the right way. It's not from sketchup either, it was modeled in VIZ2007. Something weird isnt? Thanks for your help. D. Link to comment Share on other sites More sharing options...
AJLynn Posted December 15, 2006 Share Posted December 15, 2006 Yeah, that's pretty weird. Link to comment Share on other sites More sharing options...
stanslavov Posted December 15, 2006 Share Posted December 15, 2006 where modeling building? autocad or sketchup? 10x Link to comment Share on other sites More sharing options...
diegofer_9 Posted December 15, 2006 Author Share Posted December 15, 2006 viz2007 Link to comment Share on other sites More sharing options...
neko Posted December 15, 2006 Share Posted December 15, 2006 try switching from 'perspective' view to a 'user' view. bet it goes away.... Link to comment Share on other sites More sharing options...
denham Posted December 15, 2006 Share Posted December 15, 2006 Have you tried changing from Open GL, software, or Direct 3D? Link to comment Share on other sites More sharing options...
diegofer_9 Posted December 15, 2006 Author Share Posted December 15, 2006 I switched the viewport to USER and it did go away! Thanks guys for your help, thank you prodham Link to comment Share on other sites More sharing options...
neko Posted December 15, 2006 Share Posted December 15, 2006 no problem - it used to drive me crazy too i'm always suspicious when people blame hardware first. Link to comment Share on other sites More sharing options...
