jericho0131 Posted December 17, 2006 Share Posted December 17, 2006 Hi, I am trying to make a realistic ivy in an animation, but kind of stuck now. I even have tried bionatics Ivy but they don't look realistic enough. I think the point is how to express the Ivy grows over walls or pillars. Does anyone have seen or done realistic Ivy? If so, I would like to have an advise... Thanks in advanced. Link to comment Share on other sites More sharing options...
jericho0131 Posted December 17, 2006 Author Share Posted December 17, 2006 sorry, I forgot to attach the image. I have put the bionatics Ivy in this scene. Link to comment Share on other sites More sharing options...
STRAT Posted December 17, 2006 Share Posted December 17, 2006 that ivy looks fine, just make the leaves 10 times smaller. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted December 17, 2006 Share Posted December 17, 2006 I have put the bionatics Ivy in this scene. That looks great! But if you will not be seeing it up close, perhaps just build a cage of simple polygons and map a texture with a clipmap, maybe strong bump or displacement. Link to comment Share on other sites More sharing options...
Koper Posted December 18, 2006 Share Posted December 18, 2006 here is a thread you might find interesting http://www.cgarchitect.com/vb/18063-ivy-test.html?highlight=ivy Link to comment Share on other sites More sharing options...
BrianKitts Posted December 18, 2006 Share Posted December 18, 2006 in a similar method, I've modeled a single leaf before then used max's scatter modifier on a closed spline to control the edges of where the leaves are placed. It's nice cause you can then control the density of the ivy using the quantity slider on the scatter tool, as well as being able to use the % mesh visibility so you don't kill your viewport with geometry. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted December 19, 2006 Share Posted December 19, 2006 ...i doubt you could animate this, but this ivy showed up on the vray forum. ...although i think you need to be registered with vray to view the thread about it, you should still be able to view the image since it is hosted on imageshack. http://img490.imageshack.us/img490/1302/final1024gd9.jpg http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17486 Link to comment Share on other sites More sharing options...
Ernest Burden III Posted December 19, 2006 Share Posted December 19, 2006 this ivy showed up on the vray forum. It's a bearded building! Link to comment Share on other sites More sharing options...
Chad Warner Posted December 19, 2006 Share Posted December 19, 2006 This is the link to the reference photo: http://www.fotoclub.ru/gallery/images/preview/2006/04/10/597731.jpg it really is a bearded building Link to comment Share on other sites More sharing options...
Koper Posted December 19, 2006 Share Posted December 19, 2006 i am currently working on a beard like that:D all i can say is that i am a South African in Europe:D Link to comment Share on other sites More sharing options...
jericho0131 Posted December 27, 2006 Author Share Posted December 27, 2006 Thanks, guys! The ivy posted on the vray forum was really amazing! Now I am thinking particle flow might help me build a realistic ivy. Actually, I have tried to use particle flow with Vray, and I often get this error message...UNHANDLED EXCEPTION...IRRDIANCE MAP THREAD... Is this because I generate to much particles for GI, or becuase of my poor computer? Link to comment Share on other sites More sharing options...
