diegofer_9 Posted December 18, 2006 Share Posted December 18, 2006 Hi all, Yes, me again with another question. I eventually answer some other people's questions so bear with me please , I used the file link option to reference a CAD drawing in VIZ2007. I am trying to find a smart way to work with the walls, so I am selecting the layer in which the walls are and I apply an Extrude modifier. It works quite well except that is leaves the top of the extrusion open ( even if I select CAP START or CAP END). Is there anyway around this? I want to create an exonometric of the space without the ceiling, so having those walls empty is not so great. Thanks in case somebody has an answer! Link to comment Share on other sites More sharing options...
diegofer_9 Posted December 18, 2006 Author Share Posted December 18, 2006 Oh well, nevermind, I apologize for posting without further investigation. The workaround way I found is going to AutoCAD and making sure all those walls were closed polylines, then when I link them in VIZ I can apply an EDIT MESH modifier and extrude them. Still, if anyone has a better way and wants to share it with the world, I'd love to hear it. Thanks people! Link to comment Share on other sites More sharing options...
a_w Posted December 18, 2006 Share Posted December 18, 2006 If your wall is a closed polyline in AutoCAD, you don't need the Edit Mesh modifier. The Extrude modifier will give you a closed surface. Check the Tutorials in VIZ's Help menu. There's a section called Using AutoCAD Files, which talks about this sort of problem and how to fix it. Also helpful is episode 4 of Scott Onstott's video podcast, entitled "AutoCAD 3D Modeling": http://www.scottonstott.com/vodcast/ Link to comment Share on other sites More sharing options...
