flooring problem
shangriladida
hi all,
There seems to be problems for my flooring. I wanted to use tiling for the floors, but it didnt come up, instead it appears flat. I used sketchup for my modellings, then open studio for the materials.
Does it have to do with UV? Shud i edit the images in PS? but what to edit? what shud i do? At my first render, i used an image of a single panel from the tiles, and hoping that when it renders, theyll tile it up for me. and boy~ they did...unfortunetly, the tiles were too small!!
1 more...Ive assembled all mxm materials from the gallery. Does drag and drop materials from outside studio folder help?
I need help...thanks!
modelling:skp
mock texturing: skp
final texturing: maxwell studio
render time: 60 mins (still annoyed by the grains though)
-sham-
http://www.shamsulnashriqworks.hatesit.com
First possible problem.
If you model in SketchUp and bring over to max, then sometimes your normals are facing the wrong way, so what you need to do is select the floor, then apply a 'normal' modifier. This will flip your normals to face upward so the tiles should show up.
Secondly.
If your tiles are too small, you can apply a 'UVW map' modiefier and scale your map on gizmo level to the correct size, or you can type in the tiling manually in your material settings. e.g Tiling 300 x 180 or however many tiles you need.
I model in SketchUp quite often aswell coz my job requires it, and Ive noticed all sorts of weird things when bringing it into max. Have you noticed that you cannot group objects in max, and when you select a bunch of objects and try to rotate them they just go all over the show in different directions, resetting the pivots doesnt help. Does anyone have some advice regarding this phenomenon?
If your using Maxwell through 3D Studio then you have to apply a "UVW map" modifier to any object your trying to assign a Maxwell material to if it has a map in it. The Maxwell plugin is translating the Max geometry over to the Maxwell engine but it needs the UVW map information in order to size the map correctly.
  • 2 months later...
