Josh1587140445 Posted July 17, 2002 Share Posted July 17, 2002 I am working this rendering of a pedestrian bridge. And as you can tell it is not completed. But I was wondering if anyone knows of a way I can add in the vertical supports along with cross members that would go inbetween the blue lines and follow the arch, without creating one of each and then cloning and putting it into position. Link to comment Share on other sites More sharing options...
quizzy Posted July 17, 2002 Share Posted July 17, 2002 Just animate a spline with render thickness along the spline, its done with path constraint controller in the motion menu. And thenm make a snapshot over a range of frames... Link to comment Share on other sites More sharing options...
STRAT Posted July 17, 2002 Share Posted July 17, 2002 or another method - array 1 upright along the spline using max's SPACING tool. you need more steps/verts breaking those splines up btw, you can see them kinking dreadfully. Link to comment Share on other sites More sharing options...
Josh1587140445 Posted July 17, 2002 Author Share Posted July 17, 2002 I am using VIZ 4. Plus this is just a progress rendering for my boss. So I still have to go back and fix the lofting. Link to comment Share on other sites More sharing options...
