cakewalkr7 Posted December 22, 2006 Share Posted December 22, 2006 I'm trying to put railing posts along the center of a path but as you can see from the attached image, the spacing tool's instances are moving to the outside of the path. I've tried all the options in the spacing tool dropdown box but I can't get the instances to line up along the center of the path. Anyone have any ideas why? Thanks. Link to comment Share on other sites More sharing options...
chutti Posted December 23, 2006 Share Posted December 23, 2006 Check your spline(path) interpolation. make it Higher than usual...like 18,36. and specing tools contex should be Edge. good luck!! Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted December 23, 2006 Share Posted December 23, 2006 chack if your railing posts' pivot point is in the center... Link to comment Share on other sites More sharing options...
