gaurav3d Posted December 26, 2006 Share Posted December 26, 2006 I m facing a problem, i Create a architectural scene n put vray light outside the scene top N bottom for illuminate it but it comes black,Pls tell me Why?? Like i created a box n put vray light top n bottom n we put camera inside the box n render it, it comes black. Pls help me? I put ir N quasi In Secondary n Exponential. pls Link to comment Share on other sites More sharing options...
Tim Saunders Posted December 26, 2006 Share Posted December 26, 2006 Are the lights outside or inside the box? Have you flipped normals to the box so you can see the inside faces? Link to comment Share on other sites More sharing options...
ipxstudios Posted December 27, 2006 Share Posted December 27, 2006 check to see if you have any MR materials in your material editor - that seems to create the black. Open another drawing that the lights work, save as a new drawing. delete everything (except your light and camera) then merge your scene into it. That seems to fix the problem for me. There is a bug in Vray I think, that conflicts with MR. Link to comment Share on other sites More sharing options...
gaurav3d Posted December 28, 2006 Author Share Posted December 28, 2006 ipxstudios said: check to see if you have any MR materials in your material editor - that seems to create the black. Open another drawing that the lights work, save as a new drawing. delete everything (except your light and camera) then merge your scene into it. That seems to fix the problem for me. There is a bug in Vray I think, that conflicts with MR. Thanks, I put vray lights outside the model N Didn,t Put any MR Materials or Lights.I want to send u my file if u want, pls give ur mail address. Link to comment Share on other sites More sharing options...
ipxstudios Posted December 28, 2006 Share Posted December 28, 2006 Check your environment box - change the exposure control to - "none", sometimes it defaults to logrithmic exposure and turns your scene black. Link to comment Share on other sites More sharing options...
ipxstudios Posted December 28, 2006 Share Posted December 28, 2006 If you are using a Vray camera decrease the F-stop down to around 2 or 3 Link to comment Share on other sites More sharing options...
