jophus14 Posted December 26, 2006 Share Posted December 26, 2006 Here is a building that I have been working on for several hours and I'm looking for some advice on were to go from here. I want to stay away from people, birds and vehicles I still have to add shrubs and a road bitmap, but I would appreciate some advice and/or comments. Thanks. Link to comment Share on other sites More sharing options...
jophus14 Posted December 27, 2006 Author Share Posted December 27, 2006 Quick Update: Link to comment Share on other sites More sharing options...
3DIFX Posted December 27, 2006 Share Posted December 27, 2006 Great start! Your glass texture looks excellent. The road texture looks much better. Keep working on your landscaping and grass texture. Low landscaping at the base of the building should help to soften the sharp edges a bit. Some of your tree shadows are going the wrong direction, and the tree shadows in the foreground look flat. If you are casting a shadow from a 2D image you may need to rotate the plane or take shadow casting off all together and create your shadows in post. All in all, keep up the good work! Link to comment Share on other sites More sharing options...
jophus14 Posted December 27, 2006 Author Share Posted December 27, 2006 Thanks for the comments. I see what you are saying about the foreground tree shadows. The shadows from the shrubs along the building are going in the right direction just that the last shrubs shadow on the right side falls into the shadow to the building therefore you cannot see it. I will work on the landscape some more as well. I'm using an AmbientLight lawn texture and a Vray displacement (3 inches tall) for the lawn, but it still looks like just a bitmap with noise applied, any suggestions on how to make my lawn look better? Thanks Link to comment Share on other sites More sharing options...
3DIFX Posted December 27, 2006 Share Posted December 27, 2006 Ok, now I understand what's going on with the tree shadows. A while back, I downloaded a great video tutorial on vray displacement for grass. Only problem is that I can't remember where I got if from. I tried to look this morning but still couldn't find it. If you do a search on the forums here for "vray grass displacement tutorials" loads of info should come up. From my initial observations, it appears that your grass texture may be too "tight". Try loosening up the uvw and see what happens. I usually wind up doing the grass in post because of rendering time. If you still can't find any useful information, pm me and I will zip up the video tutorial that I have and email it to you. Link to comment Share on other sites More sharing options...
ipxstudios Posted December 27, 2006 Share Posted December 27, 2006 Cast some leave shadows in the foreground and that will soften it up too, Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 1, 2007 Share Posted January 1, 2007 WOW nice image. In conjunction with the comments just made, make sure the trees have the same saturation values. The trees in front of the building look a lot greener than others. I think the rendering is almost there. Time for the post production. Are you using Vray? Can you post your glass settings? Link to comment Share on other sites More sharing options...
lafiera Posted January 1, 2007 Share Posted January 1, 2007 i like the render, the angle, the lightning, the texture etc... but your trees take away part of that, because their too flat, try using another maps or give those a little more volume with photoshop or some, so that they dont look like pictures next to a "high contrast" iluminated building Link to comment Share on other sites More sharing options...
jophus14 Posted January 1, 2007 Author Share Posted January 1, 2007 Glass material: Diffuse: RGB 22,49,26 Reflect: RGB 37,37,37; Reflect Glossiness 1.0, Subdivs 24.........NO Fresnel Refract: RGB 97,97,97; Refract Glossiness 1.0, Subdivs 24 Fog Color: RGB 168,193,174; Fog Multipier: 0.5 I placed a falloff map in the Reflect Slot in the Maps rollout Falloff is 30% in the Reflect Slot, Fresnel for Falloff Type Let me know if it doesn't turn out right. Enjoy I am going to work on the trees and then I'll repost an updated image. Thanks for the help and comments. Link to comment Share on other sites More sharing options...
