Billabong Posted December 27, 2006 Share Posted December 27, 2006 Would anyone happen to know where i could find a brick texture like the one in the image i provided.I need it for a job,doesn't need to be multicolored,Ive checked CGTextures, but no luck, any help would greatly appreciated. thanks www.billa1.com/pics/IMG_9911.JPG Link to comment Share on other sites More sharing options...
3DIFX Posted December 27, 2006 Share Posted December 27, 2006 www.archifx3dstudios.com The texture in your image looks more like concrete block. Look under "Conc. Block" on the website. CMU-SPLITFACE COLORED GROUT looks like a good match. Not free, but I hope this helps. Link to comment Share on other sites More sharing options...
daniohayon Posted December 27, 2006 Share Posted December 27, 2006 Would a procedural map work? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted December 27, 2006 Share Posted December 27, 2006 Would a procedural map work? That looks nice! I always try to use procedurals whenever I can. You have a noise pattern for bump and a random distribution of tone/bump position for the block faces. The fewer maps to keep track of, the better, and no tiling. Link to comment Share on other sites More sharing options...
daniohayon Posted December 28, 2006 Share Posted December 28, 2006 Thanks. I find that mixing or masking (or both) noise/smoke maps with differnt sizs can produce very relistic shaders and bumps. I use it a lot with the tile map for bricks and wood floors...dont like that wood floor repeating every four boards... Link to comment Share on other sites More sharing options...
Billabong Posted December 28, 2006 Author Share Posted December 28, 2006 Thanks for that procedural, this ad agencey this project is for uses Cinema 4D, so I am going to try and duplicate your procedural in it, thank you Link to comment Share on other sites More sharing options...
daniohayon Posted December 28, 2006 Share Posted December 28, 2006 I'm not familiar with Cinema 4D but let me know if you need screen shots for the shader settings Link to comment Share on other sites More sharing options...
