shikodesign2000 Posted December 29, 2006 Share Posted December 29, 2006 Hi, When I try to fix antialiasing problem, I've been told that I can make high resolution image first then I scale it down. My question is: What's the best way for doing this? Thanks, Sherif Massoud http://www.3dshore.com Link to comment Share on other sites More sharing options...
BrianKitts Posted December 29, 2006 Share Posted December 29, 2006 photoshop, GIMP....etc.... pretty much your image editor of choice. Link to comment Share on other sites More sharing options...
ipxstudios Posted December 29, 2006 Share Posted December 29, 2006 Are you using v-ray - if so can you fix the problem in the rendering process adjusting the image sampler? Link to comment Share on other sites More sharing options...
AJLynn Posted December 29, 2006 Share Posted December 29, 2006 I wonder whether the scaling approach makes sense anymore. Say you want a 1000x1000 image, so you render at 2000x2000 then use Photoshop to scale down in Bicubic mode. This is equivalent to manually supersampling at 1x1, so why not let your renderer supersample for you? They're good at it these days, they've got more than one filtering option and the better ones have adaptive methods that only supersample where they need to. Link to comment Share on other sites More sharing options...
