vray rendering comments please
kamikaze
overall looks good.
You need to render it using higher quality settings to reduce the blotchiness of the walls and stop the paintings on the left looking as if they are floating off the wall.
Also lower the stones at the bottom of your dividing wall so there is a slight reveal on the wood edging.
thanks jat..... i was expecting sumthing of that reply....
1. ill try to use Low settings..i used very low
2. good observation for the stones at the wall.thnx
3...heres my prob..the paintings that look like theyre floating, theyre resting on the wall when i modelled them!!......shadow problem?? help
I'd use at least medium settings.
using higher settings should resolve your issue with the floating paintings. Its not so much a shadow problem as that your low settings for rendering is meaning that not enough samples are being taken to give the crisp contact shadows you'd expect etc.
