make a smooth hole in a face
crz_06
I want to model a structure simular to this image. I have the basic 3d model done, just straight flat faces and now i'm looking for a smart way (algorithm, shader??) to get a simular effect as by this designer.
What do you guys think is a good approach, because modeling this by hand is hopeless. Would displacment/opacity maopping be the way to go? and if so how do I make sure that I get a thikker rim at the edges, or would converting the mesh to a editable poly and make use of the bridge function be a workaround (so not working with the faces, but work with the edges instead)
using a map or 2 might be the way to go!
make a map in ps of the holes (the holes being black on white & the edges sharp), then take that same map and duplacate it. On the second map select all the black holes and give them an outside glow from black to white so that it has soft edges (this will give the rounded edges).
then apply the first map in the opacity slot and the second map in the bump slot, also tick the double sided check-box so that the backfaces also render.
you also want to apply a uwv map to control where the holes are placed on the object.
does not look that hard to model
try CageEdit commands after bolean the original shelled shape
I'ved heard words about you, that when things seems to be blurry, youre the right person to make it clear.
anyway,may i ask, how is that cage edit commands work.and how can i access it?thanks.:)
I agree with Adriaan - for 3dsMax, his method will work the best, since you already have your basic form. :)
for instance:
Do you feel like crediting the person who created this tutorial?
[ETA] The little visual tutorial is by Jonah Barnett over on the Rhino Newsgroup. :)
If you have 3DS Max 9 than this job is a piece of cake. Can be done without any plugins and in a very fast manner – model just the exterior (how you like) / use Pro Booleans (included) for advanced cuts / shell modifier / Mental Ray for rendering (“round edges” without extra polygons – new feature) - http://download.autodesk.com/global/3dsmax/featureVideos/max9_mentalray_improvments_medium.mov.
That`s all and have fun with all those new and extremely powerful features.
Mihai
Mihai
gosh....really.thats cool.but too bad coz we dont have it yet.we still needs to stick with our older version of max
