jawadalam Posted January 7, 2007 Share Posted January 7, 2007 hi guys, i am a new user of vray.. i have a scene that i have rendered GI (radiosity) now when i tried to use vray render the result is not as clear like the one with radiosity... thanks for help in advance....... Link to comment Share on other sites More sharing options...
jophus14 Posted January 8, 2007 Share Posted January 8, 2007 There are lots of tutorials for interior lighting setup on this forum, you should definitely check them out. It is always good to post your setting and a wireframe for us to see what you are working with. A lot of people on here will help you out as long as they have some info. Link to comment Share on other sites More sharing options...
jawadalam Posted January 8, 2007 Author Share Posted January 8, 2007 i have already searched a lot of tutorials but all of them have at least one window or an open door from which the light comes from out side and makes the final result looks real ... here in my scene there is no such opening all i used here r simple vray lights insides ... i am attaching my render settings along with the max file pls kindly fix it or give me some suggestion ............thanks for ur help... Link to comment Share on other sites More sharing options...
eksg Posted January 8, 2007 Share Posted January 8, 2007 I dont know what you mean by clear.It seems that your v-ray render is way better than that of your radiosity.if you are referring to the texture,just have your settings higher so that the details would be visible.It was my first dilemna also that i had a hard time creating a scene for interior without exterior light source,but you'll get a hang of it.i'll get back on you after i see your setting. Link to comment Share on other sites More sharing options...
jawadalam Posted January 8, 2007 Author Share Posted January 8, 2007 if from high setting you mean presets i have tried on high presets but the result was thae same i have another problem with vray pluggin ...i am using vray 1.5 demo with max 8 i installed the pluggin about a month ego now when i tried to use it it gives me an error message ... as it was a demo version thats y i think it is expired now.. could any body explain how to fix this problem Link to comment Share on other sites More sharing options...
martin walker Posted January 8, 2007 Share Posted January 8, 2007 Have you tried working in LWF / Gamma Correction ???, that for me is by far the best way to get extra light into internal scenes. Link to comment Share on other sites More sharing options...
eksg Posted January 8, 2007 Share Posted January 8, 2007 i downloaded your attachment,but it seems that there is some problem with your model.i dont usually used the AEC extended,like the doors and windows coz it always give's me longer rendering time,(i dont know why).and im not sure of the scale that uve used.i suggest that you'll have it in mm,because lights in v-ray and radiosity are both sensitive when it comes to scale cause of light calculation. your v-ray light has a value of +200,which is un-usual.a value of 4-8 is enough.another tip is that v-ray light is dependent on its size also,unless you turn on the "no decay" option.change your subdivision value of light cache to at most 400.1000 is overkill for small rendering.play with the value of your dark ang light multiplier,the default is 1, u can try 2-3 or something. Link to comment Share on other sites More sharing options...
jawadalam Posted January 10, 2007 Author Share Posted January 10, 2007 thanx i will try these settings Link to comment Share on other sites More sharing options...
