PlayTime max9 mray 2 objects
vizwhiz
PlayTime
max9 mray 2 objects
mr Sun and mr Sky
Torus from mymentalray.com Thread
added A&D water mtl To The ground plane
just fooling around
ok constructive criticism and helpful hints
and Techniques ONLY. no no flames wars
Thanks
mental randy
hopefully by This Time This next week i will be doing The vray Thing
Take 2
yes i have a new LCD monitor That probably isnt adjusted yet
i just spent 10 minutes Trying To adjust The lite to backlighting
and finally figured out That i was manually adjusting The sun
(correctly) but looking at The wrong camera for The lite shadow
anywho how do you 'exclude' something from The mr sun/mr daylight ?
i cant seem To find any exclusion buttons or options anywhere for This
next question
how do i make a plane 'deform' for The water
To add swells and swales and make it look purty
really There are only 2 objects in This entire scene
Torus and ground plane = water maybe it should be somekind of a patch
instead
i guess i got To learn how To use max
(long Time way overdue viz user here)
JHV, Thanks for you input
This is Too much like fun
my d@mn mouse must have eaten some kind of jumping beans
it is an optical mouse That i am using on a wood Table surface
and it wont sit still, plus i got sunburn skin cream all over my fingers
Randy
For the swells, crank up the divisions of the plane, add a NOISE modifier and play with the Z value to get the right amount of swell, also play with the scale. Add a Turbosmooth modifier to smooth out the sharp edges and your done.
There is no way to exclude things with MRSun/sky so you will have to change the sun to "standard" to get the exclude/include dialgue. Unfortunatly you will loose all the benifits of the MRsun, ie soft area shadows. I think the IES sun has exclude, I dont know and dont want to stop a render to find out:)
JHV
JHV
Thanks for The info, i am learning something completely new
02 = waves in The wrong direction (sideways)
06 = better results
08 = surfs up
The light does reflect different with The waves are up or down
interesting
Thanks
Randy
The previous Images have NO FG GI Caustics etc
and were rendered at LOW preset settings so far
1:08 approx
This next (last) one has FG GI rendered at medium preset
9:42 exactly
(i like my new quad-core)
Thanks
Randy
i Think my mouse swallowed some polonium it is so radioactive
For open water and even rivers its best to have both, geometry and noise bump. The geometry gives the swell and the bump gives the rippes and small chop from the current and wind.
A little swell goes a long way.
I had miss read your earlier post about the light changing depending on the swell direction. It makes sence to me that the light will chage, as the swell changes it block / reveals different parts of the skylight on the horizon.
JHV
