nisus Posted January 11, 2007 Share Posted January 11, 2007 Hi All, Does anyone knows how I can display the Daylight System in the Light Lister? This worked well in max8 but doesn't work in max9 anymore. [i don't kneed to know why, just how ,-) ] rgds, nisus Link to comment Share on other sites More sharing options...
ipxstudios Posted January 11, 2007 Share Posted January 11, 2007 worked for me - I loaded the sunlight system and found it in light lister. Max 9 Link to comment Share on other sites More sharing options...
vizwhiz Posted January 11, 2007 Share Posted January 11, 2007 nisus i just Tried doing what you said and i Tried doing what ipxstudios said different Things, similar but different both showed up however in LL if They were 'standard' lights i Tried again and modified The daylight system into mr Sun and mr Sky and This DOES NOT SHOW UP in The light lister, how strange indeed it is not sure but i was able To duplicate your results but i am not able To give you an actual answer as To how To make This work (or why it doesnt) good catch randy Link to comment Share on other sites More sharing options...
nisus Posted January 12, 2007 Author Share Posted January 12, 2007 Hi all, Srry guys, I figured a few things were not well explained: - i meant daylight, not sunlight - i'm using ArchViz.mentalray UI, so MR Sun and MR Sky Glad to find out it works for you, pitty for the MR though... rgds, nisus Link to comment Share on other sites More sharing options...
