Livingroom interior
craig.t
Nice one... did you do the modeling by yourself? If so even nicer :)
The lamp seams unrealistic... if its the kind of lamp that im thinking of - then its fully transparent only if there is a glowing bulb inside - and even then the transparency isnt so high.
are you really the one who made this bro??can you teach me how to use 3dsmax?thanks bro
The scene can be built also using "Luxology modo 201 or 202",depending on the scene setup,one can do better user eithe Max/modo...same with LW.
So,all you need is few tutorials plus a lot of practice and you too can build like
image above.:cool:No one can really teach you creativity...it's all about your imaginations and the ability to draw first,then you can build it.If you can sketch what you want to build.you can build it;or you will run in to problems.
  • 4 weeks later...
