problems with sunlight shining through glass in vray 1.5
bripatfan
I have just upgraded to vray 1.5. I scene I've been working on in the previous version has a standard direct sun light shining through a glass window. Since I upgrade to 1.5, the light from the sun is no longer shining through the window. I've tried rendering without the windows in the scene, and the light comes through, so I'm pretty sure the problem is with my glass. I've tried it with the Vizmasters Simian glass and a normal glass vray material. Affect alpha and affect shadows are both checked, but still no light is coming through. What do I need to do to let the light shine through the glass?
just create a new vray material from scratch and change just one thing...make the refraction color gray (instead of black)...if that allows light to come through then build the material back to the way the other is, changing one parameter at a time and rerendering each time until you find where the problem lies
  • 2 weeks later...
The Chaos forum suggested embedding the glass within a Vray Blend material.
This way all you have to do is click on the material button in the top right corner and select VrayBlendMtl and keep the old glass as a sub material.
Nice quick fix, especially if you have an established material library.
