nbasir Posted January 17, 2007 Share Posted January 17, 2007 Hi I cant find Vray hdri load setting dialog box in vray hdri material map browser window. Can anybody show me the way. I am using vray 1.5 for max 8 Thanks in advance Link to comment Share on other sites More sharing options...
andreg Posted January 17, 2007 Share Posted January 17, 2007 just go in the render dialog's environment tab and activate the environment ref check box. then click on the none box to choose what you want to use as environment... from there you will be able to choose vrayHDRI map. After that just drag that material in your mat library and you're set. hope this helps Link to comment Share on other sites More sharing options...
nbasir Posted January 17, 2007 Author Share Posted January 17, 2007 Thanks for the hints. But I already did it. What I cant find is shown in the attached images. I cant find these dialog box Link to comment Share on other sites More sharing options...
Andrew1 Posted January 17, 2007 Share Posted January 17, 2007 Those 2 windows that you have shown are a different plugin, I belive it's from Brazil. Cheers! Link to comment Share on other sites More sharing options...
rivoli Posted January 18, 2007 Share Posted January 18, 2007 that's the native max's hdr loader (which actually is a splutterfish plugin part of max since version 6). the vray hdr map gives less control over imported hdris, but you don't necessary use it to load them in vray. Link to comment Share on other sites More sharing options...
Geoffc Posted January 21, 2007 Share Posted January 21, 2007 I had the same question. This is from the HDRI tutorial that was listed on CGarch a couple weeks ago, and the writer is using vray. Link to comment Share on other sites More sharing options...
nbasir Posted January 21, 2007 Author Share Posted January 21, 2007 Yes, I think we should ask the author. Link to comment Share on other sites More sharing options...
manta Posted January 21, 2007 Share Posted January 21, 2007 it is in fact the Max HDR loader, don't know why he's not using the Vray one... Link to comment Share on other sites More sharing options...
