parkdark Posted January 17, 2007 Share Posted January 17, 2007 Pentium 4 CPU 2.00 GHz 1GB of ram GeForce 2 MX 400 I would like to use VRay or maxwell render Link to comment Share on other sites More sharing options...
AJLynn Posted January 17, 2007 Share Posted January 17, 2007 It wouldn't be great but it would be workable. Not for Maxwell, but I've seen good Vray stuff done on machines like that, and I've used it on my old laptop that had similar specs. The video card isn't that fast but you can compensate by setting as much of your geometry as you can to display as box, and 1GB is usually enough. Would I be correct in assuming that being 17 and not having an equipment budget, you'll be learning on a student copy of Max instead of starting a company? Just do screen resolution renders instead of high-res print renders and it should be okay. Link to comment Share on other sites More sharing options...
