CORRENTES Posted January 24, 2007 Share Posted January 24, 2007 Something that i'm doing. ALready know that i have to give more detail in the window frame and better material on couch Link to comment Share on other sites More sharing options...
eksg Posted January 24, 2007 Share Posted January 24, 2007 Something that i'm doing. ALready know that i have to give more detail in the window frame and better material on couch umm...i think you should put more detail on the window frame and a better material for your couch....hehehe. i think it's ok,but it would look better if you'll put more details.my comment woud be on the background.try lowering the contrast,and i think you put it on a straight plane.if im right,try making your background on a curve object,this will give depth and some realism.okie! Link to comment Share on other sites More sharing options...
clum03 Posted January 24, 2007 Share Posted January 24, 2007 I agree with eksg that there needs to be more details in the window frames. I know its suppose to be clean and modern but the frame looks almost painted on. Also, I agree that the background image to help distinguish background and foreground. Right now the background looks really flat. Fix those and you got a nicely lit room. Link to comment Share on other sites More sharing options...
STRAT Posted January 24, 2007 Share Posted January 24, 2007 it's comming on nicely, but needs more attention to the lighting (i dont agree the frames need more work personally) - look where i've put red squares around. on the right one under the shelf you have a stark contrast where you have a strong shadow on the floor, but nothing on the wall. the wall under there would be in shadow too. and the red box on the left - again, there should be a shadow being cast off that large window frame onto the floor. Link to comment Share on other sites More sharing options...
CORRENTES Posted January 24, 2007 Author Share Posted January 24, 2007 Thank you all for the crits. I have one question STRAT: I completely agree about your repairs. The shadow cast from the window frame should be easy to fix, maybe changing the direct light position but the other shadow, i´m out of ideas how to fix. And for me, the light is one of the must important things (architecture student) cya Link to comment Share on other sites More sharing options...
ApeiNe Posted January 24, 2007 Share Posted January 24, 2007 Nice work I think you should better try to make the shadow more smooth, more "area" shadow. Also add some details to the scene. Keep up the good work Link to comment Share on other sites More sharing options...
