proces2 Posted January 24, 2007 Share Posted January 24, 2007 i think this should be possible - but i can't figure out the mechanism to do it ... i would like to take the different vertices of a single line and animate them along different paths. the basic path animation function seems only to work at the object level. i would like the same functionality (animating along a path) to work at the sub-object (vertex) level. is this possible? if so, suggestions on how it can be done? Link to comment Share on other sites More sharing options...
thatch Posted January 24, 2007 Share Posted January 24, 2007 One way to do it would be to create a spline, create Dummy objects at each vertex, then select the first vertex, assign a 'select spline' modifier to it then assign a 'linked XForm' modifier and select the controlling dummy. Do this for all your vertex then animate the dummy objects along your paths and the vertex shall follow. Link to comment Share on other sites More sharing options...
Charlie Bear Posted January 24, 2007 Share Posted January 24, 2007 Sean I found a way to do it. First you use the Ikspline modifier on a nurbs curve by points. Then create helpers in the Ikspline dialogue and turn on the axis tripod. That should create verteces that you can animate along seperate paths. Link to comment Share on other sites More sharing options...
notamondayfan Posted January 24, 2007 Share Posted January 24, 2007 y dont u just use morph targets, and animate? same way u animate facial animation on a sub level. Link to comment Share on other sites More sharing options...
