Animation help required
Stephen Thomas
I have rendered an 1800 frame flythrough animation but after viewing it it seems too fast. Does anyone know is there a way to slow it down without reducing the frame rate or re-rendering over a larger number of frames? Any software e.g. that can stretch it out over a longer time period and interpolate the frames in between?
I seem to remember that Windows Movie Maker has a feature to double the length of an avi file but not sure whether it remains as smooth after recompiling.
First post on the forum, any help gratefully received! :)
This isn't a complete solution, but it might help if combined with something else. Depending on how you are presenting it, you can always reduce the frames per second from 25 to 18 - 20 before losing too much quality. This will slow it down a bit. You'll have to fiddle with it though to ensure smooth play back. Adobe Premiere works well.
If you have individual frames then you can use max/viz ram player to adjust speed (usually comes out choppy though).
Most video editing programs will allow you to alter the length of a clip. Make your clip longer, plays back slower.
