Devin Johnston Posted January 24, 2007 Share Posted January 24, 2007 I'm trying to use the scatter tool under the Crowd option to scatter some objects on a plane; no matter what I do every new object that is created is put in the exact same position as the original object. I've tried changing the position placement numbers but regardless of what I put in all the objects are created in the same location instead of being spread out over the surface of the plane. I can't figure this out; does anyone know why this isn't working? Link to comment Share on other sites More sharing options...
thatch Posted January 24, 2007 Share Posted January 24, 2007 Are you actually creating a crowd? If not use the scatter function under compound objects. Link to comment Share on other sites More sharing options...
