creasia Posted January 24, 2007 Share Posted January 24, 2007 Hey everyone, I find that when I have two parallel faces of a vray glass (refract at Maximum) that I often have unpredictable results. Often the second face will multiply the refraction levels exponentially. I also find this with a cube shaped glass pane with 6 connected faces instead of two. I find that if I delete the back face that it will help, or set the IOR to 1.1 it helps. How are we supposed to create accurate Vray glass objects? Link to comment Share on other sites More sharing options...
