desgnr Posted February 17, 2004 Share Posted February 17, 2004 Using ADT 2004 Viz render I put a wood material on the cabinets,but they don't look right. How http://www.cgarchitect.com/forum/filepush.asp?file=interior_1.jpg can i make the cabinets show all the detail? Link to comment Share on other sites More sharing options...
kingeldar Posted February 17, 2004 Share Posted February 17, 2004 did u try adjustin map size?? cause wood map seems very very small repeated many many... many times... Link to comment Share on other sites More sharing options...
desgnr Posted February 18, 2004 Author Share Posted February 18, 2004 Where & what size do i make the wood map ? Link to comment Share on other sites More sharing options...
kingeldar Posted February 18, 2004 Share Posted February 18, 2004 right click on the material (in scene materials list) to get properties then adjust size using real world scale (french soft @my office in france...) Link to comment Share on other sites More sharing options...
desgnr Posted February 18, 2004 Author Share Posted February 18, 2004 What do you mean by real world scale Do you mean the cabinet size or ?????????????? Link to comment Share on other sites More sharing options...
kingeldar Posted February 18, 2004 Share Posted February 18, 2004 look at ur map it will have a real world scale (exemple a 50cm x 50cm wood plate) so u have to give that size as map size try with yout floor material difference will be eeaiser o see change size and see what happens (u can adjust disposition using right column) Link to comment Share on other sites More sharing options...
desgnr Posted February 18, 2004 Author Share Posted February 18, 2004 Thank all of you for your help. The only question i have is,where do i play with the settings? Should i do it in the CURRENT SCENE tab or SCRATCH TAB ? When i try to change properties in current scene tab,i dont see the changes. If i try to change in scratch,do i have to reinsert the materials. What is the right way to modify materials? Link to comment Share on other sites More sharing options...
kingeldar Posted February 18, 2004 Share Posted February 18, 2004 should see in scene changes made in CURRENT SCENE tab try to render again u should c difference if u don't i don't understad why Link to comment Share on other sites More sharing options...
desgnr Posted February 18, 2004 Author Share Posted February 18, 2004 The texture map is 1024x1024 When i set that in texture scale is goes in as 1024'x1024' How can that be right ? How do i enter it without the feet? Link to comment Share on other sites More sharing options...
kingeldar Posted February 18, 2004 Share Posted February 18, 2004 u don't have to consider texture size but real world size i mean ur 1024x1024 is a picture of a piece of wood that is i, real world 1mx1m or maybe 10cmx10cm i don't know only ur eyes can say! then when u have an idea of real world size after checking the map in a viewer you can enter that size in the boxes (my english is not good sorry) Link to comment Share on other sites More sharing options...
desgnr Posted February 18, 2004 Author Share Posted February 18, 2004 How do you put in 1mx1m when it only goes in at feet ? Also could my setting for UNITS be incorrect? What should my units be set at ? or use GENERIC ? Link to comment Share on other sites More sharing options...
kingeldar Posted February 18, 2004 Share Posted February 18, 2004 u re supposed to use same unit used in adt so if u drawed using inch unit in adt then set viz unit to inch (i talk abou meters cause i'm french and do live in meters not inch!) so the real world scale is THE REAL SIZE OF THE MAP!! if map is picture of a 10x10 inch then enter 10 inch!!!! Link to comment Share on other sites More sharing options...
