how do you extract just one Room from revit project?
vizwhiz
how do you 'extract' just one room from a revit project?
i need To 'add' 3d blocks from dwg or max format into just one room
for rendering and VRML purposes
any clues on This, i am just now beginning some R&D on how To do This
also The reverse
how do you 'add' The 3d blocks from dwg & max files into a revit project?
so That This 'update' or updated file can be sent back To The original architects
any info will be greatly appreciated
Thanks
Randy
For the first question, just create a plan call out view of the specific room that your are interested in to be exported to max/viz then go to view menu orient to other view and select your plan call out view from the list and finally orient to any 3d view i.e. s/e, s/w etc and export to dwg.
For the second question you can bring in 3d blocks from any program into revit using dwg, dxf or sat file then import it to a family editor say for example if you are importing a furniture block then bring it in the furniture family template for other blocks you can just use the generic family template.
Hope this helps
