transparency animation
hrvojezg00
In the track view just control the I think they'r called tangents positive above 0 will give you solid effect, negative below 0 will give you the transparency. You can even draw your own curve and edit it,
the window looks scary at first but after messing with it it's quite simple.
You can also do it right in your material editor, just that track view gives you better control.
Cheers !:)
