Sergio_Pontes Posted January 31, 2007 Share Posted January 31, 2007 Hi, I bought the Max9 and I intend to install it in my 4600+. I intend to buy and to install in this computer the Windows Vista 64bits. I have 32 bits computers and 64bits computers. Are possible the following combinations? - Mental Ray - DR - (cpu A) Windows Vista 64bits/ max9-64bits with (cpu B) XP Pro 32bits/ max9-32bits. - Mental Ray - Animation - each cpu rendering one entire frame. - Final Render Stage-1 R2 - DR - (cpu A) Windows Vista 64bits/ max9-64bits with (cpu B) XP Pro 32bits/ max9-32bits - Final Render Stage-1 R2 - Animation - each cpu rendering one entire frame. Thanks Sergio Link to comment Share on other sites More sharing options...
Chad Warner Posted January 31, 2007 Share Posted January 31, 2007 This was brought up in another thread. Pretty much you don't want to mix Max 9 64 bit and Max 9 32 bit. http://discussion.autodesk.com/adskcsp/thread.jspa?messageID=5386248 Link to comment Share on other sites More sharing options...
Sergio_Pontes Posted February 1, 2007 Author Share Posted February 1, 2007 Thanks Chad, I understand that I can install the Max9 in my Windows Vista as 64bits version and as 32 bits version ( 2 instalations on the same machine/ OS). When I have to render one big scene I will use only de Vista64/ Max 64 and in situations where I need to use my entire renderfarm (animations or DR) I will need to use the Max9 32bits version. In this situation I will need to be sure in not use more than 2GB RAM. Is that correct? Sérgio Link to comment Share on other sites More sharing options...
Chad Warner Posted February 1, 2007 Share Posted February 1, 2007 That's how I understand that it works. Link to comment Share on other sites More sharing options...
