Aaron2004 Posted February 5, 2007 Share Posted February 5, 2007 Hey guys, I have white stucco surrounded by white trim in an exterior rendering. Both use a combination of Output and VRAY color (no bitmaps). I'm using Linear Color Mapping. Everything is exactly as I want it (almost) except for the white stucco, which is blown out. I can tone down the intensity, but then it becomes grey in other areas. Lowering the 'recieve GI' in a material wrapper gives a similaer result. Any advice? I just want to be able to keep one object from blowing out. Thanks! Aaron Link to comment Share on other sites More sharing options...
Brian Smith Posted February 5, 2007 Share Posted February 5, 2007 there's several things you can do, but first, since you mentioned linear, have you tried anything else. I recommend reinhard with a burn value of 0.5. Increasing to 1.0 brings it closer to linear and reducing it brings it closer to exponential. Link to comment Share on other sites More sharing options...
Aaron2004 Posted February 5, 2007 Author Share Posted February 5, 2007 I have not tried reinhard yet...I was so happy with Linear. I'll try that tomorrow. Is there any other solutions besides changing light mapping? Thanks! Link to comment Share on other sites More sharing options...
Brian Smith Posted February 6, 2007 Share Posted February 6, 2007 a couple things that come to mind are: use the output rollout of the map applied to the wall materialapply a falloff or gradient map to the materialrender that particular material in a different pass or with a shadow matte material and adjust in photoshopreduce the receive GI and create a light that only affects that object Link to comment Share on other sites More sharing options...
